Re: new bing carb troubleshooting
rofman /
Bing 15mm carbs come with a 82#jet not a 86 and will work fine with that jet if you have a 2hp 15mm intake hi perf pipe if you are using the stock pipe you will need to down jet. if your engine is a 1hp you need to change the cylinder
Want to reply to this thread?
