Re: new bing carb troubleshooting
macelius-san /
You can check if the carb is getting gas if you push the tickler button on top of the carb, it will force down the float and open the needle valve, which should let the carb fill up untill it starts leaking out of the overflow hole at the top of the bowl, you will see the top of the carb get all wet with gas around the button.
Most likely You need to jet it properly, provide more details on Your setup and someone might be able to suggest where to start.
Want to reply to this thread?
