Re: Replacement EBR / Pit Bike fork tubes & ar
Gabe Bandit /
hey adam, i've got the same calipers on my maxi. they're off a crf50 pitbike. i was going to just buy a whole crf50 front end, but then i found some junkyard pitbike forks for cheap. anyway, that caliper _should_ bolt up to crf50 fork tubes. there's a ton of that stuff on ebay the only thing is most of the pitbike forks i've seen are inverted and might not have the right OD to slide into your triple tree. not sure what your welding situation is like, but getting the wheel and disk bolted up and then just welding a bracket on would be an easy fix.
Want to reply to this thread?
