Re: porting semi/confusion..
mit mortso /
are you getting the 70cc piston port puch kit? that's what i got and i'm damn near opening mine up.
things i'm planning to do:
boost port holes in the piston, make the four into two and lower.
transfers, they can easily be opened up a bit. look at the part of the cylinder that goes up against the case.
i'm gonna mess with my exhaust port a bit, maybe raise it a little and widen it. it's best to mess around with base gaskets before raising the exhaust port.
thinking of chopping off a little bit of piston skirt on the intake side.
also a single ring treatkit seems like a great place for some bigblock fiearo tech....ring ports and transfer eyebrows.
i'm saving up for a new dremel.
  porting semi/confusion..Topic by: andy andy 02/15/10 08:37PM
  Re: porting semi/confusion..Re: andy andy 02/15/10 08:44PM
  Re: porting semi/confusion..Re: mattology - mattology - 02/15/10 08:54PM
  Re: porting semi/confusion..Re: Fish tits Krauthamer Fish tits Krauthamer 02/15/10 08:55PM
  Re: porting semi/confusion..Re: andy andy 02/15/10 09:06PM
  Re: porting semi/confusion..Re: Kansas John Kansas John 02/15/10 09:44PM
  Re: porting semi/confusion..Re: Kansas John Kansas John 02/15/10 09:48PM
  Re: porting semi/confusion..Re: Kansas John Kansas John 02/15/10 09:50PM
  Re: porting semi/confusion..Re: andy andy 02/15/10 09:53PM
  Re: porting semi/confusion..Re: andy andy 02/15/10 09:57PM
  Re: porting semi/confusion..Re: Nash . Nash . 02/15/10 10:04PM
  Re: porting semi/confusion..Re: - Summerai - Christine L - Summerai - Christine L 02/16/10 12:10AM
  Re: porting semi/confusion..Re: andy andy 02/16/10 01:58AM
  Re: porting semi/confusion..Re: mit mortso mit mortso 02/16/10 03:22AM
  Re: porting semi/confusion..Re: andy andy 02/16/10 10:36AM
  Re: porting semi/confusion..Re: - Summerai - Christine L - Summerai - Christine L 02/16/10 11:31AM
  Re: porting semi/confusion..Re: andy andy 02/16/10 12:36PM
  Re: porting semi/confusion..Re: mit mortso mit mortso 02/16/10 01:21PM
  Re: porting semi/confusion..Re: Weak-Ends Tj Weak-Ends Tj 02/16/10 01:32PM
  Re: porting semi/confusion..Re: mit mortso mit mortso 02/16/10 02:03PM
  Re: porting semi/confusion..Re: mattology - mattology - 02/16/10 04:14PM
  Re: porting semi/confusion..Re: andy andy 02/16/10 04:47PM
Click here to login.
