Re: 40 t vibration-
Tommy Too Tall /
On my 40 the engine and pulley alignment was way off when I put a varriated engine on it, you might want to check that.
Also check the little bushing on the spring and the spring tension, the motor should sit still at idle and not swing slightly, if it does your spring is worn out.
Want to reply to this thread?
