Re: 40 t vibration-
swampdonkey /
I used stock replacements from treats.
The spring is in correct.
I was going to check the variator next, put the third ball back in.
If you over tighten the long engine mount bolt would that cause a vibration?
It has new bushings I cant believe it would be that?
I am lost???? Never had a vibration like that, even with old worn bushings.
Click here to login.
