Re: Kits
rofman /
If its a maxi ll 1hp 20mph you will have a hard time making it go fast it's bad geared internally restricted. With a kit and a pipe it will go 24 with stock gears. You will need to get a 32-30tooth rear sprocket custom made and grind into the case and install a 21 tooth countershaft sprocket or open up your tranny and upgrade the 13t gear set to a 2hp 16tooth gear set that is if you can find a 2hp za50 to take it from and you might as well just install the 2hp engine
Click here to login.
