Re: metrorider carb on hobbit?
latebreak /
pull the petcock and clean the screen. is there crap in your tank? run an inline filter. check the fuel line routing. is the bowl filling with gas? open the bowl drain (little hole through the subframe gets you access) and see if you get a good flow of fuel.
Click here to login.
