Re: metrorider carb on hobbit?
Supposed difference as I understand it is needles. But I guess that wouldn't apply on a Hobbit carb. Also best carb set up for a Hobbit is the Malossi PHGB set up. Otherwise run stock. Also starved for gas could be petcock, fuel line, fuel filter. Hobbits have awkward fuel line routing and I have managed to melt a fuel filter almost shut while riding. If the carb worked on another bike its most likely not the carb.
Click here to login.
