Re: photo tutorial: installing a kit for beginners
small bore /
Ring gap = space between the rings where it meets the pin.
Space should be .010 or there abouts. Formula is .003 to .005 per inch of bore.
To check, install ring [s] on piston, slide piston into jug...not far... to compress ring. By turning the piston you can expose the area where the pin is. You'll notice a gap where the ring comes together at the pin which you want to measure with a feeler gauge. If it's not at least .010, slide piston back out, remove ring and gently file the split where it meets the pin.
Repeat above until gap is correct.
This is done to allow room for expansion once things heat up. If you do not than you are running the chance of a piece of your ring breaking off.
I know of at least one member who just throws his kits on without even looking at the ring gap. So far so good but one of these days..remember I said that Reynold. :)
  photo tutorial: installing a kit for beginnersTopic by: Conrad Conrad Conrad Conrad 02/14/10 08:48PM
  Re: photo tutorial: installing a kit for beginnersRe: Noah K Noah K 02/14/10 08:53PM
  Re: photo tutorial: installing a kit for beginnersRe: Andy Andy 02/14/10 10:07PM
  Re: photo tutorial: installing a kit for beginnersRe: Saabsonettguy . Saabsonettguy . 02/14/10 10:18PM
  Re: photo tutorial: installing a kit for beginnersRe: [[ Linda ]] [[ Linda ]] 02/14/10 11:04PM
  Re: photo tutorial: installing a kit for beginnersRe: Conrad Conrad Conrad Conrad 02/14/10 11:20PM
  Re: photo tutorial: installing a kit for beginnersRe: small bore small bore 02/15/10 08:29AM
  Re: photo tutorial: installing a kit for beginnersRe: reynold reynold 02/15/10 09:35PM
  Re: photo tutorial: installing a kit for beginnersRe: Jonathan Jonathan 02/15/10 12:19AM
  Re: photo tutorial: installing a kit for beginnersRe: Nash . Nash . 02/15/10 12:24AM
  Re: photo tutorial: installing a kit for beginnersRe: Ryan Ryan 02/15/10 12:57AM
  Re: photo tutorial: installing a kit for beginnersRe: [[ Linda ]] [[ Linda ]] 02/15/10 02:16AM
  Re: photo tutorial: installing a kit for beginnersRe: Gerr Gerr 02/15/10 03:02AM
  Re: photo tutorial: installing a kit for beginnersRe: davey davey 02/15/10 03:15AM
  Re: photo tutorial: installing a kit for beginnersRe: No Lo No Lo 02/15/10 03:57AM
  Re: photo tutorial: installing a kit for beginnersRe: No Lo No Lo 02/15/10 03:58AM
  Re: photo tutorial: installing a kit for beginnersRe: † CH∆D † † CH∆D † 02/15/10 09:07AM
  Re: photo tutorial: installing a kit for beginnersRe: † CH∆D † † CH∆D † 02/15/10 09:31AM
  Re: photo tutorial: installing a kit for beginnersRe: Kelin Kelin 02/15/10 11:15AM
  Re: photo tutorial: installing a kit for beginnersRe: neezy neezy 02/15/10 12:08PM
  Re: photo tutorial: installing a kit for beginnersRe: small bore small bore 02/15/10 12:14PM
  Re: photo tutorial: installing a kit for beginnersRe: Kansas John Kansas John 02/15/10 10:01PM
  Re: photo tutorial: installing a kit for beginnersRe: [[ Linda ]] [[ Linda ]] 02/15/10 10:22PM
  Re: photo tutorial: installing a kit for beginnersRe: CtpEDsHED . CtpEDsHED . 02/15/10 10:38PM
  Re: photo tutorial: installing a kit for beginnersRe: macelius-san macelius-san 02/15/10 11:00PM
  Re: photo tutorial: installing a kit for beginnersRe: Conrad Conrad Conrad Conrad 02/15/10 11:19PM
  Re: photo tutorial: installing a kit for beginnersRe: Conrad Conrad Conrad Conrad 02/15/10 11:39PM
  Re: photo tutorial: installing a kit for beginnersRe: † CH∆D † † CH∆D † 02/16/10 12:53AM
  Re: photo tutorial: installing a kit for beginnersRe: [[ Linda ]] [[ Linda ]] 02/16/10 01:17AM
  Re: photo tutorial: installing a kit for beginnersRe: cris cris 02/16/10 02:02AM
Click here to login.
