Re: photo tutorial: installing a kit for beginners
Gerr /
Yeah, couple of steps missing:
- Chamfer the ports to minimize ring snag.
- Polish the exhaust to maximize vroomage.
-Check your squish and adjust, if necessary, by grinding & polishing the head. Check when hot as well, things expand.
- Check your ports at BDC to make sure they are all the way open. If not, add a gasket to the bottom of your jug.
- Ring gap (mentioned in another post).
- check sparkplug clearance, get shorter throw if needed.
- Lube all surfaces before assembly!
- check your torqued bolts after a short ride.
- Break it in with regular, non-synthetic oil, at around 32:1 - jet accordingly.
- Keep it under 3/4 throttle for a hundred miles.
- Plug chop, rejet, then plug chop again. If you change anything, plug chop again.
  photo tutorial: installing a kit for beginnersTopic by: Conrad Conrad Conrad Conrad 02/14/10 08:48PM
  Re: photo tutorial: installing a kit for beginnersRe: Noah K Noah K 02/14/10 08:53PM
  Re: photo tutorial: installing a kit for beginnersRe: Andy Andy 02/14/10 10:07PM
  Re: photo tutorial: installing a kit for beginnersRe: Saabsonettguy . Saabsonettguy . 02/14/10 10:18PM
  Re: photo tutorial: installing a kit for beginnersRe: [[ Linda ]] [[ Linda ]] 02/14/10 11:04PM
  Re: photo tutorial: installing a kit for beginnersRe: Conrad Conrad Conrad Conrad 02/14/10 11:20PM
  Re: photo tutorial: installing a kit for beginnersRe: small bore small bore 02/15/10 08:29AM
  Re: photo tutorial: installing a kit for beginnersRe: reynold reynold 02/15/10 09:35PM
  Re: photo tutorial: installing a kit for beginnersRe: Jonathan Jonathan 02/15/10 12:19AM
  Re: photo tutorial: installing a kit for beginnersRe: Nash . Nash . 02/15/10 12:24AM
  Re: photo tutorial: installing a kit for beginnersRe: Ryan Ryan 02/15/10 12:57AM
  Re: photo tutorial: installing a kit for beginnersRe: [[ Linda ]] [[ Linda ]] 02/15/10 02:16AM
  Re: photo tutorial: installing a kit for beginnersRe: Gerr Gerr 02/15/10 03:02AM
  Re: photo tutorial: installing a kit for beginnersRe: davey davey 02/15/10 03:15AM
  Re: photo tutorial: installing a kit for beginnersRe: No Lo No Lo 02/15/10 03:57AM
  Re: photo tutorial: installing a kit for beginnersRe: No Lo No Lo 02/15/10 03:58AM
  Re: photo tutorial: installing a kit for beginnersRe: † CH∆D † † CH∆D † 02/15/10 09:07AM
  Re: photo tutorial: installing a kit for beginnersRe: † CH∆D † † CH∆D † 02/15/10 09:31AM
  Re: photo tutorial: installing a kit for beginnersRe: Kelin Kelin 02/15/10 11:15AM
  Re: photo tutorial: installing a kit for beginnersRe: neezy neezy 02/15/10 12:08PM
  Re: photo tutorial: installing a kit for beginnersRe: small bore small bore 02/15/10 12:14PM
  Re: photo tutorial: installing a kit for beginnersRe: Kansas John Kansas John 02/15/10 10:01PM
  Re: photo tutorial: installing a kit for beginnersRe: [[ Linda ]] [[ Linda ]] 02/15/10 10:22PM
  Re: photo tutorial: installing a kit for beginnersRe: CtpEDsHED . CtpEDsHED . 02/15/10 10:38PM
  Re: photo tutorial: installing a kit for beginnersRe: macelius-san macelius-san 02/15/10 11:00PM
  Re: photo tutorial: installing a kit for beginnersRe: Conrad Conrad Conrad Conrad 02/15/10 11:19PM
  Re: photo tutorial: installing a kit for beginnersRe: Conrad Conrad Conrad Conrad 02/15/10 11:39PM
  Re: photo tutorial: installing a kit for beginnersRe: † CH∆D † † CH∆D † 02/16/10 12:53AM
  Re: photo tutorial: installing a kit for beginnersRe: [[ Linda ]] [[ Linda ]] 02/16/10 01:17AM
  Re: photo tutorial: installing a kit for beginnersRe: cris cris 02/16/10 02:02AM
Click here to login.
