Re: Using a Tomos Rear Sprocket on a Derbi
mattology - /
I've got the same thing going on , noah. I'm putting a streetmate spoked 16" on my revolution. However, since the offset of the wheel is slightly different, i've designed a hub spacer that will set the chain tension and alignment proper. I chose to have the adapter bolt to the wheel, and then bolt the sprocket to the adapter rather than using four long bolts because I didn't like the shear levels i was putting the longer bolts into.
I'll be machining it as our saebaja car becomes closer to completion.
Want to reply to this thread?
