Re: Spark only at idle
Polini Blasty Gnar Gnar /
points are clean?(try sanding em of corrosion), is the gap wide enough?, maybe something's up with the connection from the ignition coil to the plug, everything grounded strong enough even during engine vibrations? Not sure what to tell ya other than follow each wire around and feel em up, connections, dirt n oils. If a condenser is bad, will it kill the spark??
Click here to login.
