Re: Variator/Exhaust Inquiry
Jesse Stephenson /
Well, you're juggling clutch stall rpm, spring preload, spring rate/dampening rate, and variator adjustments. If one was really patient you can do a lot of tuning with the variator settings and have a really narrow powerband pipe that came on at whatever rpm you so like.
