Re: Variator/Exhaust Inquiry
Flagrant - /
So from a practical standpoint unless you use very light variator weights to delay variation you would want to use a midrange pipe. Ideally you would want your variateur to keep the engine at the exact RPM at which your pipe produces maximum power at all speeds. So you are juggling variateur weights and possibly drive sprockets and port timing. It should take a lot of time to even get close
