Re: 15mm bing party
Tom STL /
The jet range, get 60 - 72 (sounds like a lot, its only 6 jets, about $18 + shipping), and you should have all you need to get your setup running perfectly.
You can still use the choke function without the long plastic piece, but if you want it, you can pull it off of your old carb.
Click here to login.
