Re: 15mm bing party
[[ Linda ]] /
You'll need jets too. It comes with a jet (an 82, I think), but that's going to be too big for your setup unless you've got a kit, a wildly ported cylinder, massive air leaks, or your setup is over 3 standard deviations away from the mean jet size for a stock/mostly stock setup.
I think mid 60's to low 70's would be about right if you were running a stock setup or a stock cylinder with a pipe. However, you should check the spreadsheet too, and buy a range of jets -- we can't tell you exactly what you need, so you'll have to try out a few and figure out which one is best.
Want to reply to this thread?
