Re: Minimum depth of
Cold Trailer GARzan Justin /
You mean case matching the _transfers_
You can "ramp" them out at the top, and leave the bottom mostly stock, and this will probably give you a little more torque, but why? I shape mine to match the cylinder all the way to the bottom, where it starts to right-angle into the crankcase, then blend into that angle, if that makes sense. You'll get more revs, and a lot more power this way.
Click here to login.
