Re:
Name Removed /
I revved my polini way pass 10,000 rpm on a stock crank for over a year. If it had the lubrication hole on the rod, durability wise I would say it's better than any other crank you could find. Unless the motor was allowed to run lean I've never seen or heard of one failing. Keep it
Click here to login.
