Re: biggest carb youve run on a moped
Brian /
Cant see any moped needing a carb bigger than 30mm, a 1340cc harley runs in between a 40 and 50mm carb.But most built harleys run a max of 7000 rpms. Only thing good that will come out of a bigger carb is more RPMs. A 80cc or 90cc if it gets revved up high enough could probably hold it, THEORETICALLY u could hit 20000 rpms if you could get a carb that big to work right.A 80or 90 cc motor at 14000 rpms might not be able to suck more anymore than through a 26 mm if you go up to 28 im sure you would get a higher max rpm maybe 16000.I think CV Constant Velocity carbs might be worth looking into.
  biggest carb youve run on a mopedTopic by: Nash . Nash . 02/10/10 10:54AM
  biggest carb youve run on a mopedRe: Rick Rick 02/10/10 11:03AM
  Re: biggest carb youve run on a mopedRe: Gabe Bandit Gabe Bandit 02/10/10 11:08AM
  Re: biggest carb youve run on a mopedRe: naz. naz. 02/10/10 11:16AM
  Re: biggest carb youve run on a mopedRe: Rick Rick 02/10/10 01:15PM
  Re: biggest carb youve run on a mopedRe: Fish tits Krauthamer Fish tits Krauthamer 02/10/10 01:39PM
  Re: biggest carb youve run on a mopedRe: bryan bryan 02/10/10 01:41PM
  Re: biggest carb youve run on a mopedRe: mattology - mattology - 02/10/10 01:53PM
  Re: biggest carb youve run on a mopedRe: clay clay 02/10/10 02:47PM
  Re: biggest carb youve run on a mopedRe: Sunset Paul Sunset Paul 02/10/10 02:54PM
  Re: biggest carb youve run on a mopedRe: Rafter Rafter 02/10/10 02:58PM
  polini?Re: Frank Tunna Frank Tunna 02/10/10 03:52PM
  Re: polini?Re: clay clay 02/10/10 04:03PM
  Re: polini?Re: zeke zeke 02/11/10 06:34AM
  Re: polini?Re: clay clay 02/11/10 10:18AM
  Re: biggest carb youve run on a mopedRe: Dez Dez 02/11/10 02:00PM
  Re: biggest carb youve run on a mopedRe: Freebird Freebird 02/11/10 02:45PM
  Re: biggest carb youve run on a mopedRe: elliot elliot 02/11/10 04:14PM
  Re: biggest carb youve run on a mopedRe: Not Tate Not Tate 02/11/10 04:18PM
  Re: biggest carb youve run on a mopedRe: Orphan Frick Orphan Frick 02/11/10 06:41PM
  Re: biggest carb youve run on a mopedRe: bryan bryan 02/11/10 08:14PM
  Re: biggest carb youve run on a mopedRe: zeke zeke 02/11/10 09:33PM
  Re: biggest carb youve run on a mopedRe: Lance Campeau Lance Campeau 02/11/10 09:57PM
  Re: biggest carb youve run on a mopedRe: rofman rofman 02/11/10 10:58PM
  Re: biggest carb youve run on a mopedRe: Brian Brian 02/12/10 05:17PM
Want to reply to this thread?
