Re: biggest carb youve run on a moped
rofman /
Man I run 14-15mm bings on puch polini and hit 50mph. I run 19-21 dellortos on polini 4 ped and hit 52-54mph( the 19mm seems faster ) with much more power through the range but top speed not that much more then you would think Ihit 44-45 mph with a puch polini with a 12mm bing 68# jet and the take off was great A carb that is underrated is a 17mm bing. man on piston port 60-70cc kits its fast but parts ( correct slides, jet holders and needles ) need to be matched to factory specs. all bings need to be matched to factory specs. There many jet holders ( 212 a 222 217 215 ect ) in 12mm 14mm 15mm 17mm ect and a few slides #24 #51 in 12mm 14mm 15mm and a few different needles in bing carbs. Many mopeds that have worked on that won't idle have miss matched bing parts. This also leads to poor jetting info being passed on in moped repair forum sometimes. Large kits 74cc and even ported polini work great with mikuni 24mm flat slide its a easy carb to tune but it sucks my maxi tank dry in 40mins. In my opinion 22mm and larger carbs should be used in large and or ported kits on bikes with large tanks
  biggest carb youve run on a mopedTopic by: Nash . Nash . 02/10/10 10:54AM
  biggest carb youve run on a mopedRe: Rick Rick 02/10/10 11:03AM
  Re: biggest carb youve run on a mopedRe: Gabe Bandit Gabe Bandit 02/10/10 11:08AM
  Re: biggest carb youve run on a mopedRe: naz. naz. 02/10/10 11:16AM
  Re: biggest carb youve run on a mopedRe: Rick Rick 02/10/10 01:15PM
  Re: biggest carb youve run on a mopedRe: Fish tits Krauthamer Fish tits Krauthamer 02/10/10 01:39PM
  Re: biggest carb youve run on a mopedRe: bryan bryan 02/10/10 01:41PM
  Re: biggest carb youve run on a mopedRe: mattology - mattology - 02/10/10 01:53PM
  Re: biggest carb youve run on a mopedRe: clay clay 02/10/10 02:47PM
  Re: biggest carb youve run on a mopedRe: Sunset Paul Sunset Paul 02/10/10 02:54PM
  Re: biggest carb youve run on a mopedRe: Rafter Rafter 02/10/10 02:58PM
  polini?Re: Frank Tunna Frank Tunna 02/10/10 03:52PM
  Re: polini?Re: clay clay 02/10/10 04:03PM
  Re: polini?Re: zeke zeke 02/11/10 06:34AM
  Re: polini?Re: clay clay 02/11/10 10:18AM
  Re: biggest carb youve run on a mopedRe: Dez Dez 02/11/10 02:00PM
  Re: biggest carb youve run on a mopedRe: Freebird Freebird 02/11/10 02:45PM
  Re: biggest carb youve run on a mopedRe: elliot elliot 02/11/10 04:14PM
  Re: biggest carb youve run on a mopedRe: Not Tate Not Tate 02/11/10 04:18PM
  Re: biggest carb youve run on a mopedRe: Orphan Frick Orphan Frick 02/11/10 06:41PM
  Re: biggest carb youve run on a mopedRe: bryan bryan 02/11/10 08:14PM
  Re: biggest carb youve run on a mopedRe: zeke zeke 02/11/10 09:33PM
  Re: biggest carb youve run on a mopedRe: Lance Campeau Lance Campeau 02/11/10 09:57PM
  Re: biggest carb youve run on a mopedRe: rofman rofman 02/11/10 10:58PM
  Re: biggest carb youve run on a mopedRe: Brian Brian 02/12/10 05:17PM
Want to reply to this thread?
