Re: biggest carb youve run on a moped
Freebird /
What rafter is saying is, the 4 petal intake of a polini will not flow all of a 24mm carb. You might still gain some power, but you arent making the most of the carb because your intake wont flow enough.
Some french 50cc bikes run up to 30mm carbs, but you have to have a reed block big enough to flow that (cr80 sized) and they have bikes with clutches and pipes made to work together in a very specific powerband. If you engine is tuned to make the grunt of its power between say 9k-12k rpm, and you have a clutch that can grab at 8.5k then a huge carb can work, but if you have a puch and your clutch is grabbing at 4k rpm, but your bike starts making power at 8k rpm, well I dont see a huge carb helping at all, probably just making your low end shit.
Atleast thats how I would see it. I know a lot of this years polini cup bikes will be running 28mm carbs.
  biggest carb youve run on a mopedTopic by: Nash . Nash . 02/10/10 10:54AM
  biggest carb youve run on a mopedRe: Rick Rick 02/10/10 11:03AM
  Re: biggest carb youve run on a mopedRe: Gabe Bandit Gabe Bandit 02/10/10 11:08AM
  Re: biggest carb youve run on a mopedRe: naz. naz. 02/10/10 11:16AM
  Re: biggest carb youve run on a mopedRe: Rick Rick 02/10/10 01:15PM
  Re: biggest carb youve run on a mopedRe: Fish tits Krauthamer Fish tits Krauthamer 02/10/10 01:39PM
  Re: biggest carb youve run on a mopedRe: bryan bryan 02/10/10 01:41PM
  Re: biggest carb youve run on a mopedRe: mattology - mattology - 02/10/10 01:53PM
  Re: biggest carb youve run on a mopedRe: clay clay 02/10/10 02:47PM
  Re: biggest carb youve run on a mopedRe: Sunset Paul Sunset Paul 02/10/10 02:54PM
  Re: biggest carb youve run on a mopedRe: Rafter Rafter 02/10/10 02:58PM
  polini?Re: Frank Tunna Frank Tunna 02/10/10 03:52PM
  Re: polini?Re: clay clay 02/10/10 04:03PM
  Re: polini?Re: zeke zeke 02/11/10 06:34AM
  Re: polini?Re: clay clay 02/11/10 10:18AM
  Re: biggest carb youve run on a mopedRe: Dez Dez 02/11/10 02:00PM
  Re: biggest carb youve run on a mopedRe: Freebird Freebird 02/11/10 02:45PM
  Re: biggest carb youve run on a mopedRe: elliot elliot 02/11/10 04:14PM
  Re: biggest carb youve run on a mopedRe: Not Tate Not Tate 02/11/10 04:18PM
  Re: biggest carb youve run on a mopedRe: Orphan Frick Orphan Frick 02/11/10 06:41PM
  Re: biggest carb youve run on a mopedRe: bryan bryan 02/11/10 08:14PM
  Re: biggest carb youve run on a mopedRe: zeke zeke 02/11/10 09:33PM
  Re: biggest carb youve run on a mopedRe: Lance Campeau Lance Campeau 02/11/10 09:57PM
  Re: biggest carb youve run on a mopedRe: rofman rofman 02/11/10 10:58PM
  Re: biggest carb youve run on a mopedRe: Brian Brian 02/12/10 05:17PM
Want to reply to this thread?
