My lights on my swinger1 quit on me!! Wtf?
Charlie BUZZARD /
they would flicker on the way home and then they went out all together. The tail light and the healight went out at once...
The horn works... Checked the switch that switches to where the low beam would be if it had one. It's on the high beam like it should be and it's conecting fine.
I checked the two brown wires that conect to the frame, and I made sure that the wires in the wire block were tightly connected...
Could it be my lighting coil went out? If so why does the horn still work? I'm stumped.
and neither light is blown...
Click here to login.
