Re: sachs 505 with pipe and air filter jetting iss
Vlado vlado /
get the matching thread bolt at auto or hardware store, cut about 1" from it, cut a ridge to the end where it was cut for flat screwdriver, then clean decomp valve access hole with degreasing fluid like brake cleaner spray or acetone, then dip about 1/2" of the bolt into JB wel, screw in with screwdriver tightly and let set for overnight- that will work, did for me
Want to reply to this thread?
