Re: how exactly does rev range work?
Cold Trailer GARzan Justin /
For the most part, pipes will 'boost' the power band at the rev range they're designed for. Low end pipes boost low end, high end pipes boost high end; regardless of the cylinder porting. BUT, a low end pipe on a cylinder ported for high revs won't be as effective as a low end pipe on a cylinder ported for the same (low) rev range as the pipe; and vice versa.
Cylinder porting takes "precedence" over the pipe range. You'll be able to rev a low end pipe high on a cylinder with high port timings (ported for high revs), such as a Tecno/Proma circuit on a heavily ported DMP. The Dutchies are getting over 12k RPM out of the circuit pipes, which are "low end" pipes. Conversely, if you were to throw a Simonini (high end pipe) on to a stock cylinder (low end cylinder), you'd never get into the pipe range because the port timings on the cylinder won't let you rev high enough.
Maybe that helps?
  how exactly does rev range work?Topic by: andy andy 02/08/10 10:09PM
  Re: how exactly does rev range work?Re: Dan Dan 02/08/10 10:37PM
  Re: how exactly does rev range work?Re: andy andy 02/08/10 10:58PM
  Re: how exactly does rev range work?Re: [[ Linda ]] [[ Linda ]] 02/09/10 12:00AM
  Re: how exactly does rev range work?Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/09/10 12:27AM
  Re: how exactly does rev range work?Re: Charles Cole (OFMC) Charles Cole (OFMC) 02/09/10 12:32AM
  Re: how exactly does rev range work?Re: andy andy 02/09/10 10:27AM
  Re: how exactly does rev range work?Re: andy andy 02/09/10 10:33AM
  Re: how exactly does rev range work?Re: Crackstar X Crackstar X 02/09/10 10:41AM
  Re: how exactly does rev range work?Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/09/10 11:15AM
  Re: how exactly does rev range work?Re: Nash . Nash . 02/09/10 02:38PM
  Re: how exactly does rev range work?Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/09/10 02:55PM
  Re: how exactly does rev range work?Re: andy andy 02/09/10 06:45PM
  Re: how exactly does rev range work?Re: rofman rofman 02/09/10 07:03PM
  Re: how exactly does rev range work?Re: mit mortso mit mortso 02/10/10 12:51AM
  Re: how exactly does rev range work?Re: andy andy 02/09/10 07:39PM
  Re: how exactly does rev range work?Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/09/10 09:57PM
  Re: how exactly does rev range work?Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/10/10 01:14AM
  Re: how exactly does rev range work?Re: ezdasnowman!! ezdasnowman!! 02/10/10 01:15AM
  Re: how exactly does rev range work?Re: andy andy 02/10/10 01:50PM
Want to reply to this thread?
