Hobbit Dio Intake Tuners
Rick /
Thanks Brian. I carefully measured to ensure that I minimzed the open space in the cases to maintain maximum transfer velocity. The reeds sit about 3/8" off the crankshaft. The plate blocks the gapping std hole and I positioned the reed all of the way to the back side of the engine. The pic doesn't show it, but I also made a filler block to close up the front half of the case hole. All of which is effectively like stuffing the crank.
If you've seen my YT videos on Carb Options & Reed Valves, you'll also see where I had the benefit of blank cases to work with, and that my first 4-petal Yamaha reed setup wasn't ideal with a lot of extra open space.
These Dio blocks have a lot of capacity and so I wanted to minimize the space to maintain a strong carb velocity. That's why I made the stuffer; to cut down on turbulance and provide some fill so the transition from the carb to the block issn't too great.
  Hobbit Dio Intake TunersTopic by: matt matt 02/08/10 02:38PM
  Re: Hobbit Dio Intake TunersRe: boobby boobby 02/08/10 02:45PM
  Re: Hobbit Dio Intake TunersRe: sort of mike sort of mike 02/08/10 03:00PM
  Re: Hobbit Dio Intake TunersRe: Charles Cole (OFMC) Charles Cole (OFMC) 02/08/10 04:26PM
  Re: Hobbit Dio Intake TunersRe: sort of mike sort of mike 02/08/10 04:29PM
  Re: Hobbit Dio Intake TunersRe: ThunderB ThunderB 02/08/10 09:19PM
  Re: Hobbit Dio Intake TunersRe: sort of mike sort of mike 02/08/10 10:57PM
  Re: Hobbit Dio Intake TunersRe: jankster jankster 02/08/10 10:58PM
  Re: Hobbit Dio Intake TunersRe: boobby boobby 02/08/10 11:33PM
  Re: Hobbit Dio Intake TunersRe: the worst terry the worst terry 02/08/10 11:35PM
  Re: Hobbit Dio Intake TunersRe: Thunderbird Thunderbird 02/09/10 12:04AM
  Re: Hobbit Dio Intake TunersRe: Charles Cole (OFMC) Charles Cole (OFMC) 02/09/10 12:26AM
  Re: Hobbit Dio Intake TunersRe: the worst terry the worst terry 02/09/10 01:13AM
  Re: Hobbit Dio Intake TunersRe: rock finally shredding pow rock finally shredding pow 02/09/10 02:01AM
  Re: Hobbit Dio Intake TunersRe: the worst terry the worst terry 02/09/10 04:12AM
  Re: Hobbit Dio Intake TunersRe: jankster jankster 02/09/10 08:40AM
  Re: Hobbit Dio Intake TunersRe: Andy Haldeman Andy Haldeman 02/09/10 01:40PM
  Re: Hobbit Dio Intake TunersRe: Mike Mike 02/09/10 02:54PM
  Re: Hobbit Dio Intake TunersRe: peter peter 02/09/10 02:58PM
  Re: Hobbit Dio Intake TunersRe: naz naz 02/09/10 05:40PM
  Re: Hobbit Dio Intake TunersRe: peter peter 02/09/10 03:11PM
  Re: Hobbit Dio Intake TunersRe: the worst terry the worst terry 02/09/10 03:13PM
  Re: Hobbit Dio Intake TunersRe: Sadder Joey P Sadder Joey P 02/09/10 03:31PM
  Hobbit Dio Intake TunersRe: Rick Rick 02/09/10 04:37PM
  Hobbit Dio Intake TunersRe: Rick Rick 02/09/10 04:49PM
  Re: Hobbit Dio Intake TunersRe: Nele Nele 02/09/10 04:47PM
  Re: Hobbit Dio Intake TunersRe: Mike Mike 02/09/10 04:48PM
  Re: Hobbit Dio Intake TunersRe: Nele Nele 02/09/10 07:03PM
  Re: Hobbit Dio Intake TunersRe: ThunderB ThunderB 02/09/10 09:09PM
  Re: Hobbit Dio Intake TunersRe: I.R.E. Rick I.R.E. Rick 02/09/10 11:23PM
  Re: Hobbit Dio Intake TunersRe: the worst terry the worst terry 02/10/10 12:02AM
  Re: Hobbit Dio Intake TunersRe: Mike Mike 02/10/10 12:30AM
  Re: Hobbit Dio Intake TunersRe: Rick Rick 02/10/10 02:50AM
  Re: Hobbit Dio Intake TunersRe: rock finally shredding pow rock finally shredding pow 02/10/10 02:53AM
  Re: Hobbit Dio Intake TunersRe: Rick Rick 02/10/10 03:11AM
  Re: Hobbit Dio Intake TunersRe: ThunderB ThunderB 02/10/10 04:03PM
  Re: Hobbit Dio Intake TunersRe: oneeyedjack oneeyedjack 02/10/10 08:47PM
  Re: Hobbit Dio Intake TunersRe: I.R.E. Rick I.R.E. Rick 02/10/10 10:04PM
  Re: Hobbit Dio Intake TunersRe: Matt Bengry Matt Bengry 02/10/10 10:47PM
  Re: Hobbit Dio Intake TunersRe: Gabe Bandit Gabe Bandit 02/10/10 11:46PM
  Re: Hobbit Dio Intake TunersRe: Rick Rick 02/11/10 10:45AM
  Re: Hobbit Dio Intake TunersRe: the worst terry the worst terry 02/11/10 02:29PM
  Re: Hobbit Dio Intake TunersRe: Mike Mike 02/11/10 02:40PM
  Re: Hobbit Dio Intake TunersRe: Freebird Freebird 02/11/10 02:46PM
  Re: Hobbit Dio Intake TunersRe: ThunderB ThunderB 02/11/10 02:48PM
  Re: Hobbit Dio Intake TunersRe: the worst terry the worst terry 02/11/10 02:55PM
  Hobbit Dio Intake TunersRe: Rick Rick 02/11/10 03:39PM
  Re: Hobbit Dio Intake TunersRe: ThunderB ThunderB 02/11/10 09:11PM
Click here to login.
