Re: puch airsal "80" kit...
-Riprips- ** /
I also had the same issue with the spark plug threads stripping out. Replaced with a high comp head (the combustion chambers looked identical). The kit was really unimpressive for top end on the stock porting, but really woke up after widening and raising the exhaust port and matching the cases.
Also, if you happen to fuck up a ring you can use this guy...
http://www.treatland.tv/peugeot-motobecane-polini-70cc-ring-p/polini-70cc-ring-206.0120.htm
As far as the piston, I have no Idea where to get another. I've seen some that look very similar but haven't gotten to take measurements of mine to compare.
Click here to login.
