Re: Puch 12v points on tomos
[[ Linda ]] /
So the tapers and all that are fine? I was looking at doing this to my A3 (but with stock 6v stuff), but the Puch stator plate seemed much "thicker" for lack of a better term. I guess if you're using the Puch flywheel too, then it wouldn't be as much of an issue, if the flywheel lined up with the depth/whatever other dimensions of the crankshaft.
Also, I'm assuming you have to get creative with the timing?
Click here to login.
