Re: 1978 Solo Odyssey tuning
Better Fส็็็็็็็็็็็็็็็็ster /
The problem with casting a new intake is the small reed block. The block can only handle a 12mm carb, so you'll need a larger one. I had good luck making one of those 19mm dellorto pocketbike intakes fit to mine. I just had to expand the stud holes. I think I have pics somewhere... I have to find my flash drive.
put on a larger carb, port it (the ports are tiny just like most other stock bikes), make a custom exhaust with a larger header and an expansion chamber. I'm not sure if another bike has the same angle for the pipe. If you looked around, I'll bet you could find one close. I'm pretty sure puch kits will fit with a little modification.
I know the 2 in the 40/2 was the number of gears. I thought mine might be the only one in the states. I've never heard of anyone else having a 40/2. everyone else I've seen with an odyssey had the 40/1 version. I'm not sure if the 40 means anything really. Mine is 49cc for sure, so it can't be the cc.
  1978 Solo Odyssey tuningTopic by: M-Tenn Aaron M-Tenn Aaron 02/07/10 12:43PM
  Re: 1978 Solo Odyssey tuningRe: Jesse Stephenson Jesse Stephenson 02/07/10 03:57PM
  Re: 1978 Solo Odyssey tuningRe: no groms no blasters no groms no blasters 02/07/10 04:00PM
  Re: 1978 Solo Odyssey tuningRe: Uphill Nater Uphill Nater 02/07/10 04:10PM
  Re: 1978 Solo Odyssey tuningRe: M-Tenn Aaron M-Tenn Aaron 02/07/10 08:19PM
  Re: 1978 Solo Odyssey tuningRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 03/06/13 04:09PM
  Re: 1978 Solo Odyssey tuningRe: Nash . Nash . 02/07/10 11:24PM
  Re: 1978 Solo Odyssey tuningRe: no groms no blasters no groms no blasters 02/08/10 02:25AM
  Re: 1978 Solo Odyssey tuningRe: Uphill Nater Uphill Nater 02/08/10 06:24AM
  Re: 1978 Solo Odyssey tuningRe: derek derek 02/08/10 10:40AM
  Re: 1978 Solo Odyssey tuningRe: M-Tenn Aaron M-Tenn Aaron 02/08/10 05:39PM
  Re: 1978 Solo Odyssey tuningRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 02/08/10 01:59PM
  Re: 1978 Solo Odyssey tuningRe: derek derek 02/08/10 09:31PM
  Re: 1978 Solo Odyssey tuningRe: M-Tenn Aaron M-Tenn Aaron 02/08/10 11:25PM
  Re: 1978 Solo Odyssey tuningRe: derek derek 02/09/10 12:03AM
  Re: 1978 Solo Odyssey tuningRe: M-Tenn Aaron M-Tenn Aaron 02/09/10 02:38PM
  Re: 1978 Solo Odyssey tuningRe: M-Tenn Aaron M-Tenn Aaron 02/09/10 06:07PM
  Re: 1978 Solo Odyssey tuningRe: derek derek 02/10/10 12:38AM
  Re: 1978 Solo Odyssey tuningRe: M-Tenn Aaron M-Tenn Aaron 02/10/10 01:06AM
  Re: 1978 Solo Odyssey tuningRe: derek derek 02/10/10 01:35AM
  Re: 1978 Solo Odyssey tuningRe: M-Tenn Aaron M-Tenn Aaron 02/10/10 10:12AM
  Re: 1978 Solo Odyssey tuningRe: derek derek 02/10/10 11:07AM
  Re: 1978 Solo Odyssey tuningRe: M-Tenn Aaron M-Tenn Aaron 02/10/10 02:00PM
  Re: 1978 Solo Odyssey tuningRe: derek derek 02/10/10 09:20PM
  Re: 1978 Solo Odyssey tuningRe: M-Tenn Aaron M-Tenn Aaron 02/11/10 01:27AM
  Re: 1978 Solo Odyssey tuningRe: derek derek 02/11/10 01:46AM
  Re: 1978 Solo Odyssey tuningRe: M-Tenn Aaron M-Tenn Aaron 02/11/10 11:06AM
  Re: 1978 Solo Odyssey tuningRe: Better Fส็็็็็็็็็็็็็็็็ster Better Fส็็็็็็็็็็็็็็็็ster 02/11/10 02:45PM
  Re: 1978 Solo Odyssey tuningRe: M-Tenn Aaron M-Tenn Aaron 02/11/10 05:31PM
  Re: 1978 Solo Odyssey tuningRe: M-Tenn Aaron M-Tenn Aaron 02/11/10 06:36PM
  Re: 1978 Solo Odyssey tuningRe: stanyon stanyon 02/12/10 03:38PM
  Re: 1978 Solo Odyssey tuningRe: M-Tenn Aaron M-Tenn Aaron 02/12/10 06:12PM
  Re: 1978 Solo Odyssey tuningRe: M-Tenn Aaron M-Tenn Aaron 02/12/10 06:20PM
  Re: 1978 Solo Odyssey tuningRe: M-Tenn Aaron M-Tenn Aaron 03/06/13 04:36PM
  Re: 1978 Solo Odyssey tuningRe: Jeremy Husk Jeremy Husk 03/06/13 04:51PM
  Re: 1978 Solo Odyssey tuningRe: M-Tenn Aaron M-Tenn Aaron 03/06/13 05:26PM
Click here to login.
