Re: V1 CLUTCH pad Variation
Bryan Decaterina /
that makes since, Treats just makes a point such a point to say that each set of pads is very specific, and to make sure you get the correct one, or their not going to fit. I just assumed that was to say that all the variations of the V1 like the Fantic or the VL, V1h etc., used a different clutch. I am running at higher than stock RMP's, with the 47mm Polini, would a stock clutch be sufficient? Pros/Cons? thanks for all your advise
Want to reply to this thread?
