Re: Moby Malossi CDI Fried?
Mike /
with cdi, you usually need to spin the flywheel a bit faster to get spark out of it. I use a hand-held CORDED drill to spin my flywheel while testing spark and checking timing, it'll spin the motor at close to 2k!, Continuity doesn't always show everything wrong within a circuit, a single strand of a multi-strand copper wire can have 1 ohm of resistance and show up good as continuity, but it can't carry the amperage needed for any electrical consumer. Check what your voltages are coming out of your stator going to the cdi box with the motor spinning (drill) Check to see if you're getting voltage to the coil from the cdi box. You can see if your pick-up coil is generating voltage as well. Cdi's are pretty basic, maybe not as much as points but still pretty simple.
Good luck.
  Moby Malossi CDI Fried?Topic by: Uphill Nater Uphill Nater 02/07/10 05:13AM
  Re: Moby Malossi CDI Fried?Re: Bret Hoffman Bret Hoffman 02/07/10 05:19AM
  Re: Moby Malossi CDI Fried?Re: Uphill Nater Uphill Nater 02/07/10 05:38AM
  Re: Moby Malossi CDI Fried?Re: steve steve 02/07/10 11:13AM
  Re: Moby Malossi CDI Fried?Re: naz naz 02/07/10 11:20AM
  Re: Moby Malossi CDI Fried?Re: Emperor Swagustus Emperor Swagustus 02/07/10 12:21PM
  Re: Moby Malossi CDI Fried?Re: Uphill Nater Uphill Nater 02/07/10 03:40PM
  Re: Moby Malossi CDI Fried?Re: Crackstar X Crackstar X 02/08/10 09:47AM
  Re: Moby Malossi CDI Fried?Re: Uphill Nater Uphill Nater 02/08/10 05:21PM
  Re: Moby Malossi CDI Fried?Re: Crackstar X Crackstar X 02/08/10 10:03PM
  Re: Moby Malossi CDI Fried?Re: br∞ks readman br∞ks readman 02/08/10 06:08PM
  Re: Moby Malossi CDI Fried?Re: naz naz 02/08/10 10:26PM
  Re: Moby Malossi CDI Fried?Re: Uphill Nater Uphill Nater 02/09/10 03:45AM
  Re: Moby Malossi CDI Fried?Re: Crackstar X Crackstar X 02/09/10 08:28AM
  Re: Moby Malossi CDI Fried?Re: Uphill Nater Uphill Nater 02/09/10 03:03PM
  Re: Moby Malossi CDI Fried?Re: Crackstar X Crackstar X 02/09/10 03:08PM
  Re: Moby Malossi CDI Fried?Re: Uphill Nater Uphill Nater 02/11/10 01:15AM
  Re: Moby Malossi CDI Fried?Re: Crackstar X Crackstar X 02/11/10 10:10AM
  Re: Moby Malossi CDI Fried?Re: Uphill Nater Uphill Nater 02/11/10 08:45PM
  Re: Moby Malossi CDI Fried?Re: Crackstar X Crackstar X 02/12/10 02:24PM
  Re: Moby Malossi CDI Fried?Re: cris cris 02/11/10 09:13PM
  Re: Moby Malossi CDI Fried?Re: Kim Kim 02/12/10 05:29AM
  Re: Moby Malossi CDI Fried?Re: Mike Mike 02/12/10 01:04PM
  Re: Moby Malossi CDI Fried?Re: bacon bacon 02/12/10 03:03PM
  Re: Moby Malossi CDI Fried?Re: bacon bacon 02/12/10 03:04PM
  Re: Moby Malossi CDI Fried?Re: Uphill Nater Uphill Nater 02/17/10 08:18PM
  Re: Moby Malossi CDI Fried?Re: Uphill Nater Uphill Nater 02/17/10 08:20PM
  Re: Moby Malossi CDI Fried?Re: Kim Kim 02/17/10 08:41PM
  Re: Moby Malossi CDI Fried?Re: Uphill Nater Uphill Nater 02/17/10 10:24PM
  Re: Moby Malossi CDI Fried?Re: Jesse Stephenson Jesse Stephenson 02/17/10 10:27PM
  Re: Moby Malossi CDI Fried?Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 02/17/10 10:32PM
  Re: Moby Malossi CDI Fried?Re: Uphill Nater Uphill Nater 02/17/10 11:03PM
  Re: Moby Malossi CDI Fried?Re: Uphill Nater Uphill Nater 03/04/10 04:46AM
  Re: Moby Malossi CDI Fried?Re: Ian T Ian T 03/04/10 06:33AM
Want to reply to this thread?
