Re: alukit 70 reeds and exhaust?
Weak-Ends Tj /
Well, you got some good info and some biased info..stock reeds will be fine for the alukit, if you want to upgrade it's up to you, most of the reeds will be $10-$20 range. As long as you get an exhaust made for the A35 you will be set. If you get the alukit you can keep your stock carb you don't have to get a bigger one, just get a bigger main jet.
Click here to login.
