Re: 65cc metra compression
Cold Trailer GARzan Justin /
"What should the compression be?"
Lots.
Check your deck height/squish clearance. Put some modeling clay on top of your piston, bolt it back together, and turn it to TDC. It should squish out to just a hair less than 1mm at the thinnest point. Adjust with your base gasket stack.
Want to reply to this thread?
