Re: 65cc metra compression
Flagrant - /
150 psi puts you at a 10:1 compression ratio. You could go up to 176 for a 12:1 ratio. Beyond that with a cast iron cylinder it gets less reliable. If it were aluminum you could push it to 15.5:1 or 228 psi. All while using high test pumped gas of course
Want to reply to this thread?
