Re: Dial-A-Jet... Never rejet again? IDK. Discuss
juneaujim /
Ryan- The diffuser isn't in the circuit at WOT because the needle (which controls midrange) is all the way out of the needle jet thereby leaving only the main jet to do the fuel metering chores. Remember that the main jet screws into the needle jet not a jet holder. The needle jet has a larger ID than the main but is subsequently blocked to a smaller diameter by the needle. Removing the needle leaves only the smaller main in the way. That's why. As to the adjustable needles, I'm making up a couple of batches of them for common moped carbs and when they're done I'll post all the info here. There is a fair amount of calibration involved in making the jigs etc. to make such a simple modification. Many Kodiak Research techs use these on their personal engines. Rotax and Bing never did make it standard on their aircraft engines because of all the bozos who don't/won't learn about tuning and no doubt would go out and promptly seize their engines or something. The Kodiak is a division of Rotax based in the Bahamas that produces their aircraft engines.
As far as tuning mopeds vs aircraft... two strokes is two strokes, the torque curve requirements are the only significant difference as a propeller puts a constant load on the engine rather than a variable load like our mopeds. A two stroke is a load sensitive engine which is a whole other chapter. If I told you when I first started messing around with dinky engines you'd know why I was naturally bald and I might not be hip anymore.
  Dial-A-Jet... Never rejet again? IDK. DiscussTopic by: Deadped Ryan Deadped Ryan 02/05/10 11:02PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Deadped Ryan Deadped Ryan 02/05/10 11:10PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: andrewhed andrewhed 02/05/10 11:29PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Josh B. Josh B. 02/06/10 12:01AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: peter peter 02/06/10 01:15AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Name Removed Name Removed 02/06/10 01:43AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Jesse -B Jesse -B 02/06/10 10:12AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Jeremy Shay Jeremy Shay 02/06/10 01:46AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Charlie BUZZARD Charlie BUZZARD 02/06/10 05:06AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Allie ! Allie ! 02/06/10 05:46AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Alex Russell-Wilkes Alex Russell-Wilkes 02/06/10 10:32AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: rofman rofman 02/06/10 11:01AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: zeke zeke 02/06/10 11:01AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Not Tate Not Tate 02/06/10 12:03PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: mit mortso mit mortso 02/06/10 03:42PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Chris Rice Chris Rice 02/08/10 01:38PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Not Tate Not Tate 02/06/10 03:43PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Sunset Paul Sunset Paul 02/06/10 04:03PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Not Tate Not Tate 02/06/10 05:40PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: steve steve 02/06/10 09:34PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: steve steve 02/06/10 09:36PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Deadped Ryan Deadped Ryan 02/07/10 04:07PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: steve steve 02/07/10 04:42PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Deadped Ryan Deadped Ryan 02/07/10 05:45PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Andy Haldeman Andy Haldeman 02/07/10 05:54PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: durepo durepo 02/08/10 12:00AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: juneaujim juneaujim 02/08/10 10:12AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Deadped Ryan Deadped Ryan 02/08/10 01:13PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: juneaujim juneaujim 02/10/10 07:31AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Deadped Ryan Deadped Ryan 02/10/10 07:58AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Dick Tortuga Dick Tortuga 02/08/10 12:48PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Kelin Kelin 02/08/10 05:29PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Andy Haldeman Andy Haldeman 02/08/10 07:31PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Josh G Josh G 02/08/10 07:51PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Josh G Josh G 02/08/10 07:57PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Chris Rice Chris Rice 02/08/10 11:37PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Andy Haldeman Andy Haldeman 02/09/10 01:41PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: peter peter 02/09/10 03:00PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/09/10 03:05PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: daan daan 02/09/10 03:15PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Deadped Ryan Deadped Ryan 02/09/10 06:05PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Deadped Ryan Deadped Ryan 02/24/10 02:05PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Austin Tastic Austin Tastic 02/26/10 03:13PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Austin Tastic Austin Tastic 02/26/10 03:14PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: CtpEDsHED . CtpEDsHED . 02/26/10 09:31PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: CtpEDsHED . CtpEDsHED . 02/26/10 09:39PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: daan daan 02/27/10 08:37AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Bill_O_MAtic Bill_O_MAtic 03/07/10 06:03PM
Want to reply to this thread?
