Re: Dial-A-Jet... Never rejet again? IDK. Discuss
juneaujim /
These have been around since I had a ponytail and I'm naturally bald now. They work especially well for snowmachines because of the way they are operated i.e. in the hills, rapidly changing altitudes, temps. etc. They do not change your main jet which is where many of us operate as the chart posted shows, that is, at W.O.T. There are many more reasons to have to re-tune your carburator other than temperature. Altitude, condition of your seals and gaskets, age of the fuel (Evaporation of the gasoline in your mixed fuel richens your gas/oil ratio as the oil stays behind thus leaning the air/fuel mixture when it runs through a fixed jet.) varnish, humidity and some other things all will affect the ultimate air/fuel mixture your engine eventually sees. Moped engines are primarily fuel cooled so it is important to get it right for longevity even more so than for power. Racers run leaner because they need that extra tenth of a second and also expect to rebuild/re-ring after every session and have the money to do that. When I was flying two stroke powered airplanes full time we modified our Bings so that we could move the needles up and down in flight, sometimes so much so that the needle jet began to operate as the main jet. This would occur say, on a flight that began at sea level and passed through 10,000 feet with a temperature difference of 70 to 90 degrees. This setup could work for some mopeds but only makes needle adjustment easy and more finely adjustable which means it'll get done. If it's a drag, you'rre not going to do it, That's my two cents and change. Just ask Fishsticks about remotely adjustable needles, he knows
  Dial-A-Jet... Never rejet again? IDK. DiscussTopic by: Deadped Ryan Deadped Ryan 02/05/10 11:02PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Deadped Ryan Deadped Ryan 02/05/10 11:10PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: andrewhed andrewhed 02/05/10 11:29PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Josh B. Josh B. 02/06/10 12:01AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: peter peter 02/06/10 01:15AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Name Removed Name Removed 02/06/10 01:43AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Jesse -B Jesse -B 02/06/10 10:12AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Jeremy Shay Jeremy Shay 02/06/10 01:46AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Charlie BUZZARD Charlie BUZZARD 02/06/10 05:06AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Allie ! Allie ! 02/06/10 05:46AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Alex Russell-Wilkes Alex Russell-Wilkes 02/06/10 10:32AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: rofman rofman 02/06/10 11:01AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: zeke zeke 02/06/10 11:01AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Not Tate Not Tate 02/06/10 12:03PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: mit mortso mit mortso 02/06/10 03:42PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Chris Rice Chris Rice 02/08/10 01:38PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Not Tate Not Tate 02/06/10 03:43PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Sunset Paul Sunset Paul 02/06/10 04:03PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Not Tate Not Tate 02/06/10 05:40PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: steve steve 02/06/10 09:34PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: steve steve 02/06/10 09:36PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Deadped Ryan Deadped Ryan 02/07/10 04:07PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: steve steve 02/07/10 04:42PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Deadped Ryan Deadped Ryan 02/07/10 05:45PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Andy Haldeman Andy Haldeman 02/07/10 05:54PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: durepo durepo 02/08/10 12:00AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: juneaujim juneaujim 02/08/10 10:12AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Deadped Ryan Deadped Ryan 02/08/10 01:13PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: juneaujim juneaujim 02/10/10 07:31AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Deadped Ryan Deadped Ryan 02/10/10 07:58AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Dick Tortuga Dick Tortuga 02/08/10 12:48PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Kelin Kelin 02/08/10 05:29PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Andy Haldeman Andy Haldeman 02/08/10 07:31PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Josh G Josh G 02/08/10 07:51PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Josh G Josh G 02/08/10 07:57PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Chris Rice Chris Rice 02/08/10 11:37PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Andy Haldeman Andy Haldeman 02/09/10 01:41PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: peter peter 02/09/10 03:00PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/09/10 03:05PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: daan daan 02/09/10 03:15PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Deadped Ryan Deadped Ryan 02/09/10 06:05PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Deadped Ryan Deadped Ryan 02/24/10 02:05PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Austin Tastic Austin Tastic 02/26/10 03:13PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Austin Tastic Austin Tastic 02/26/10 03:14PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: CtpEDsHED . CtpEDsHED . 02/26/10 09:31PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: CtpEDsHED . CtpEDsHED . 02/26/10 09:39PM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: daan daan 02/27/10 08:37AM
  Re: Dial-A-Jet... Never rejet again? IDK. DiscussRe: Bill_O_MAtic Bill_O_MAtic 03/07/10 06:03PM
Click here to login.
