what do you fellas mean by wrist pin alignment? because it's the same amount into the piston on both sides with the clips in both their grooves. also is there supposed to be resistance at a certain point when i move the piston with only the intake manifold open.. there seems to be more than before i cleaned it but then again that could be a good thing since the exhaust was almost clogged before i cleaned it
