Re: 24mm mikuni on a35
Organ Robbin' /
Well if you make an intake, you should make it so it bolts right on. If you throw some stuff together you might want to match the intake port to the intake you use. You might just want to buy the jcams special intake, which should work well with the 24, but I think he uses 24's that are flange mounted.
  24mm mikuni on a35Topic by: cc250r cc250r 02/02/10 11:20PM
  Re: 24mm mikuni on a35Re: Hex Inverter Hex Inverter 02/02/10 11:28PM
  Re: 24mm mikuni on a35Re: Weak-Ends Tj Weak-Ends Tj 02/02/10 11:41PM
  Re: 24mm mikuni on a35Re: Frank Horrigan Frank Horrigan 02/02/10 11:47PM
  Re: 24mm mikuni on a35Re: Hex Inverter Hex Inverter 02/02/10 11:57PM
  Re: 24mm mikuni on a35Re: Cc250r Cc250r 02/03/10 12:35AM
  Re: 24mm mikuni on a35Re: zeke zeke 02/03/10 12:40AM
  Re: 24mm mikuni on a35Re: Trevor Yee Trevor Yee 02/03/10 12:40AM
  Re: 24mm mikuni on a35Re: Hex Inverter Hex Inverter 02/03/10 12:49AM
  Re: 24mm mikuni on a35Re: brandon. brandon. 02/03/10 01:55AM
  Re: 24mm mikuni on a35Re: Cc250r Cc250r 02/03/10 09:09AM
  Re: 24mm mikuni on a35Re: Frank Horrigan Frank Horrigan 02/03/10 10:14AM
  Re: 24mm mikuni on a35Re: zeke zeke 02/03/10 09:55AM
  Re: 24mm mikuni on a35Re: Mo Peds Mo Peds 02/03/10 10:31AM
  Re: 24mm mikuni on a35Re: Mars™   Mars™   02/03/10 10:38AM
  Re: 24mm mikuni on a35Re: . (Nick) . (Nick) 02/03/10 11:11AM
  Re: 24mm mikuni on a35Re: Organ Robbin' Organ Robbin' 02/03/10 11:46AM
  Re: 24mm mikuni on a35Re: Hex Inverter Hex Inverter 02/03/10 01:47PM
  Re: 24mm mikuni on a35Re: Cc250r Cc250r 02/03/10 02:09PM
  Re: 24mm mikuni on a35Re: Weak-Ends Tj Weak-Ends Tj 02/05/10 12:28AM
  Re: 24mm mikuni on a35Re: Cc250r Cc250r 02/05/10 10:56AM
  Re: 24mm mikuni on a35Re: Fish tits Krauthamer Fish tits Krauthamer 02/03/10 02:38PM
  Re: 24mm mikuni on a35Re: Jaa Bee Jaa Bee 02/03/10 03:37PM
  Re: 24mm mikuni on a35Re: Hex Inverter Hex Inverter 02/04/10 11:28PM
  Re: 24mm mikuni on a35Re: Cc250r Cc250r 02/05/10 12:11AM
  Re: 24mm mikuni on a35Re: mit mortso mit mortso 02/05/10 04:11AM
  Re: 24mm mikuni on a35Re: jupoloopo jupoloopo 02/05/10 04:31PM
  Re: 24mm mikuni on a35Re: Cc250r Cc250r 02/05/10 10:15PM
  Re: 24mm mikuni on a35Re: Cc250r Cc250r 02/08/10 01:09AM
  Re: 24mm mikuni on a35Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/08/10 12:32PM
  Re: 24mm mikuni on a35Re: Cc250r Cc250r 02/08/10 01:02PM
  Re: 24mm mikuni on a35Re: Organ Robbin' Organ Robbin' 02/08/10 01:15PM
  Re: 24mm mikuni on a35Re: Cc250r Cc250r 02/08/10 03:44PM
  Re: 24mm mikuni on a35Re: Organ Robbin' Organ Robbin' 02/08/10 03:52PM
  Re: 24mm mikuni on a35Re: Weak-Ends Tj Weak-Ends Tj 02/08/10 05:03PM
  Re: 24mm mikuni on a35Re: Organ Robbin' Organ Robbin' 02/08/10 05:24PM
  Re: 24mm mikuni on a35Re: Cc250r Cc250r 02/08/10 11:24PM
  Re: 24mm mikuni on a35Re: Organ Robbin' Organ Robbin' 02/09/10 11:10AM
  Re: 24mm mikuni on a35Re: Rob @t ATTN! Burrito Rob @t ATTN! Burrito 02/09/10 12:36PM
  Re: 24mm mikuni on a35Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/09/10 01:35PM
  Re: 24mm mikuni on a35Re: Flagrant - Flagrant - 02/09/10 01:41PM
  Re: 24mm mikuni on a35Re: Cc250r Cc250r 02/09/10 10:49PM
  Re: 24mm mikuni on a35Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/09/10 11:08PM
  Re: 24mm mikuni on a35Re: Cc250r Cc250r 02/09/10 11:11PM
  Re: 24mm mikuni on a35Re: Organ Robbin' Organ Robbin' 02/10/10 11:23AM
Want to reply to this thread?
