Re: Which weight for stock pa50ii with some bits
Get Blatzed /
they wont work. honda weights are a different size. those polini weights will work for a derbi tjt variator, if you plan on putting one of those on your hobbit, but if you're sticking with the stock variator, you're easiest option is to drill out the weights. i'd say use pa50I weights, but those will probably be too light on a non-kitted bike. just take your stock weights, and drill out the hole slightly larger. then test em out, then repeat as necessary.
Click here to login.
