Re: Alternate swingarm options, what's out there?
Serious Business /
I could swap over the rear end of an Indian and gain 1.5" length as well as have a full 5" clearance side to side from for to aft, however I'd have to remove the pedal assembly, run the pivot bolt where the pedal bolt goes and trim off the exhaust hanger and shorten the other side a mere 1/2".
Not to mention space out the upper shock attachment points amongst other things.
Click here to login.
