Re: Alternate swingarm options, what's out there?
Mike Bartell /
I'd cut the stock arm about 2" from the pivot and use that to make a new swing arm, then box it all with thin sheet metal. Use the rear of the swingarm like drop outs.
Threaded rod with 4 nuts would work for a jig on the rear and you could build in a little bit of an angle to make sure everything clears where the swing arm attaches.
Measure 12 times weld once.
Click here to login.
