Re: im so sick of this moby!!!
Graham Motzing /
the easiest way to make sure your carb is opening is to just pull on the cable from the top of the carb while holding wot with your other hand. if you can pull the cable up, it means it isnt fully open... done.
that said, it sounds like you're having airleak problems. If you're using the shorty intake manifold, its because the dellorto is hitting the cooling fins and not pushing all the way on, or if you're using the malossi manifold, its because the manifold isn't sealing flat, it has to have a little tabby ground off.
take the motor off, take the whole intake tract apart, clean it all up, cut some new gaskets, and assemble it all together. when you get it running, if it doesn't fix it, try spraying some carb cleaner or starting fluid around the intake manifold. if the bike dies, it has an air leak.
if that seems to be fixed, start looking at the electrical system.
have you read fred's guide yet? maybe try the troubleshooting section of the motobecane manual?
  im so sick of this moby!!!Topic by: kyle kyle 02/01/10 06:06PM
  Re: im so sick of this moby!!!Re: Un Lethocerus Un Lethocerus 02/01/10 06:09PM
  Re: im so sick of this moby!!!Re: aph1979 aph1979 02/01/10 06:12PM
  Re: im so sick of this moby!!!Re: kyle kyle 02/01/10 06:13PM
  Re: im so sick of this moby!!!Re: kyle kyle 02/01/10 06:15PM
  Re: im so sick of this moby!!!Re: Un Lethocerus Un Lethocerus 02/01/10 06:19PM
  Re: im so sick of this moby!!!Re: kyle kyle 02/01/10 06:26PM
  Re: im so sick of this moby!!!Re: Un Lethocerus Un Lethocerus 02/01/10 06:37PM
  Re: im so sick of this moby!!!Re: kyle kyle 02/01/10 06:49PM
  Re: im so sick of this moby!!!Re: roadent$ craig roadent$ craig 02/01/10 08:40PM
  Re: im so sick of this moby!!!Re: d d 02/01/10 09:23PM
  Re: im so sick of this moby!!!Re: kyle kyle 02/01/10 09:35PM
  Re: im so sick of this moby!!!Re: kyle kyle 02/01/10 09:36PM
  Re: im so sick of this moby!!!Re: d d 02/01/10 09:54PM
  Re: im so sick of this moby!!!Re: kyle kyle 02/01/10 10:17PM
  Re: im so sick of this moby!!!Re: Andy Andy 02/02/10 12:11AM
  Re: im so sick of this moby!!!Re: kyle kyle 02/02/10 04:15PM
  Re: im so sick of this moby!!!Re: kyle kyle 02/02/10 08:13PM
  Re: im so sick of this moby!!!Re: Graham Motzing Graham Motzing 02/03/10 10:18AM
  Re: im so sick of this moby!!!Re: .Allen Schlung .Allen Schlung 02/03/10 02:06PM
  Re: im so sick of this moby!!!Re: Marc Marc 02/03/10 03:26PM
  Re: im so sick of this moby!!!Re: kyle kyle 02/03/10 04:07PM
  Re: im so sick of this moby!!!Re: Marc Marc 02/03/10 04:18PM
  Re: im so sick of this moby!!!Re: kyle kyle 02/04/10 06:42PM
Want to reply to this thread?
