Re: im so sick of this moby!!!
d /
every setup is different, so no, I'm not sure.. But it should be pretty close given there are no airleaks.. Did you verify timing at 2mm btdc? If your timing is set right, it makes a big difference. I tried a couple different things with a few stock pipes I have. I found that cutting the pipe attached to the inside of the endcap down to about 2.5 inches gave me the best results. I also opened up the header on the pipe itself about 1-1.5mm. Side gapped plug. Other suff. Basically a bunch of little things that, when put together, got me about 8mph..
  im so sick of this moby!!!Topic by: kyle kyle 02/01/10 06:06PM
  Re: im so sick of this moby!!!Re: Un Lethocerus Un Lethocerus 02/01/10 06:09PM
  Re: im so sick of this moby!!!Re: aph1979 aph1979 02/01/10 06:12PM
  Re: im so sick of this moby!!!Re: kyle kyle 02/01/10 06:13PM
  Re: im so sick of this moby!!!Re: kyle kyle 02/01/10 06:15PM
  Re: im so sick of this moby!!!Re: Un Lethocerus Un Lethocerus 02/01/10 06:19PM
  Re: im so sick of this moby!!!Re: kyle kyle 02/01/10 06:26PM
  Re: im so sick of this moby!!!Re: Un Lethocerus Un Lethocerus 02/01/10 06:37PM
  Re: im so sick of this moby!!!Re: kyle kyle 02/01/10 06:49PM
  Re: im so sick of this moby!!!Re: roadent$ craig roadent$ craig 02/01/10 08:40PM
  Re: im so sick of this moby!!!Re: d d 02/01/10 09:23PM
  Re: im so sick of this moby!!!Re: kyle kyle 02/01/10 09:35PM
  Re: im so sick of this moby!!!Re: kyle kyle 02/01/10 09:36PM
  Re: im so sick of this moby!!!Re: d d 02/01/10 09:54PM
  Re: im so sick of this moby!!!Re: kyle kyle 02/01/10 10:17PM
  Re: im so sick of this moby!!!Re: Andy Andy 02/02/10 12:11AM
  Re: im so sick of this moby!!!Re: kyle kyle 02/02/10 04:15PM
  Re: im so sick of this moby!!!Re: kyle kyle 02/02/10 08:13PM
  Re: im so sick of this moby!!!Re: Graham Motzing Graham Motzing 02/03/10 10:18AM
  Re: im so sick of this moby!!!Re: .Allen Schlung .Allen Schlung 02/03/10 02:06PM
  Re: im so sick of this moby!!!Re: Marc Marc 02/03/10 03:26PM
  Re: im so sick of this moby!!!Re: kyle kyle 02/03/10 04:07PM
  Re: im so sick of this moby!!!Re: Marc Marc 02/03/10 04:18PM
  Re: im so sick of this moby!!!Re: kyle kyle 02/04/10 06:42PM
Click here to login.
