E50 Clutch cover interferes with Pressure plate?!?
Andrew R /
Has anyone run into this problem in rebuilding an E50? When I put the clutch cover on and screw it down completely it begins to rub the pressure plate as if i need an extra thick gasket?
I have taken the thing completely apart to make sure the bearings and every part is located correctly and its all fine circlips and washers all where they need to be. No problem until i put the cover on.
Click here to login.
