Re: Best pipe for a stock pinto?
Nash . /
i'm running a maxi petcock on my pinto, no leaks. although running an actual pinto-designed petcock is better since the switch sits vertically instead of horizontally. either works, maxi works in a pinch but id go for the right petcock. make sure you get the most expensive one you can, ive had bad luck with cheap pinto petcocks springing leaks.
  Best pipe for a stock pinto?Topic by: The Man The Man 01/30/10 12:00AM
  Re: Best pipe for a stock pinto?Re: Tony montana Tony montana 01/30/10 12:47AM
  Re: Best pipe for a stock pinto?Re: The Man The Man 01/30/10 01:06AM
  Re: Best pipe for a stock pinto?Re: The Man The Man 01/30/10 01:08AM
  Re: Best pipe for a stock pinto?Re: Jacob Worley Jacob Worley 01/30/10 01:52AM
  Re: Best pipe for a stock pinto?Re: Harry Crank Harry Crank 01/30/10 01:56AM
  Re: Best pipe for a stock pinto?Re: Nash . Nash . 01/30/10 01:59AM
  Re: Best pipe for a stock pinto?Re: The Man The Man 01/30/10 02:22AM
  Re: Best pipe for a stock pinto?Re: Nash . Nash . 01/30/10 03:00AM
  Re: Best pipe for a stock pinto?Re: Tom STL Tom STL 01/30/10 03:10AM
  Re: Best pipe for a stock pinto?Re: Aaron Bajongus Aaron Bajongus 01/30/10 04:03AM
  Re: Best pipe for a stock pinto?Re: Tom STL Tom STL 01/30/10 04:54AM
  Re: Best pipe for a stock pinto?Re: Tate Tate 01/30/10 10:31AM
  Re: Best pipe for a stock pinto?Re: . . . . 01/30/10 11:42AM
  Re: Best pipe for a stock pinto?Re: eobanb eobanb 01/31/10 01:38AM
  Re: Best pipe for a stock pinto?Re: derek derek 02/01/10 01:40PM
  Re: Best pipe for a stock pinto?Re: Tom STL Tom STL 02/01/10 02:01PM
  Re: Best pipe for a stock pinto?Re: [[ Linda ]] [[ Linda ]] 02/01/10 07:18PM
  Re: Best pipe for a stock pinto?Re: Nash . Nash . 02/01/10 08:55PM
  Re: Best pipe for a stock pinto?Re: Nash . Nash . 02/01/10 08:57PM
  Re: Best pipe for a stock pinto?Re: The Man The Man 02/01/10 11:21PM
  Re: Best pipe for a stock pinto?Re: Charlie BUZZARD Charlie BUZZARD 02/02/10 06:24AM
Want to reply to this thread?
