Re: AV10 gurus...won't you come itt
Shalerrr rrr /
basically what that article i linked you to says is that the mykitech cases shown on the link we've been kicking around in the last couple months is basically a big reed block welded to a set of stock cases that have been hacked. you can see evidence of this in that picture in that thread. maybe elliot and some of the other '77 dudes that have actual experience with this case can clear this up a little.
the inlet on the polini cases is plenty big, and the reeds are considerably larger than those normally adapted to puch polini 4 petal setups, so while you arent at a disadvantage compared to what everyone else has access to, its not exactly next level stuff anymore.
a couple things to note about the polini cases, particularly in use with other cylinders is that at times the cylinder skirt will protrude into the inlet area. you can see this in the photo that i ripped off mosquito fleet ryan's blog.
he's running the same setup that i am (polini cases, 50cc malossi G2 cylinder). i'm pretty sure that should just be hacked off. also, you can see the lump in the inlet area created by the cylinder stud. this probably interrupts flow a bit too.
  AV10 gurus...won't you come ittTopic by: . (Nick) . (Nick) 01/28/10 08:34PM
  Re: AV10 gurus...won't you come ittRe: .Allen Schlung .Allen Schlung 01/28/10 08:48PM
  Re: AV10 gurus...won't you come ittRe: motobee motobee 01/28/10 09:33PM
  Re: AV10 gurus...won't you come ittRe: mattology - mattology - 01/28/10 09:32PM
  Re: AV10 gurus...won't you come ittRe: . (Nick) . (Nick) 01/28/10 09:48PM
  Re: AV10 gurus...won't you come ittRe: . (Nick) . (Nick) 01/28/10 09:53PM
  Re: AV10 gurus...won't you come ittRe: Bret Hoffman Bret Hoffman 01/28/10 10:04PM
  Re: AV10 gurus...won't you come ittRe: Sunset Paul Sunset Paul 01/28/10 10:31PM
  Re: AV10 gurus...won't you come ittRe: Uphill Nate Uphill Nate 01/28/10 11:27PM
  Re: AV10 gurus...won't you come ittRe: . (Nick) . (Nick) 01/28/10 11:37PM
  Re: AV10 gurus...won't you come ittRe: Dave Dave 01/29/10 12:49AM
  Re: AV10 gurus...won't you come ittRe: naz naz 01/29/10 02:03AM
  Re: AV10 gurus...won't you come ittRe: Crackstar X Crackstar X 01/29/10 02:03AM
  Re: AV10 gurus...won't you come ittRe: Crackstar X Crackstar X 01/29/10 02:15AM
  Re: AV10 gurus...won't you come ittRe: nick nick 01/29/10 11:11AM
  Re: AV10 gurus...won't you come ittRe: motobee motobee 01/29/10 03:26PM
  Re: AV10 gurus...won't you come ittRe: joey speaking for round joey speaking for round 01/29/10 07:13PM
  Re: AV10 gurus...won't you come ittRe: Ben Ben 01/29/10 08:02PM
  Re: AV10 gurus...won't you come ittRe: Jesse Stephenson Jesse Stephenson 01/29/10 08:56PM
  Re: AV10 gurus...won't you come ittRe: joey speaking for round joey speaking for round 01/29/10 08:10PM
  Re: AV10 gurus...won't you come ittRe: .Allen Schlung .Allen Schlung 01/29/10 08:16PM
  Re: AV10 gurus...won't you come ittRe: .Allen Schlung .Allen Schlung 01/29/10 09:07PM
  Re: AV10 gurus...won't you come ittRe: .Allen Schlung .Allen Schlung 01/29/10 09:12PM
  Re: AV10 gurus...won't you come ittRe: . (Nick) . (Nick) 01/29/10 09:43PM
  Re: AV10 gurus...won't you come ittRe: . (Nick) . (Nick) 01/30/10 11:03AM
  Re: AV10 gurus...won't you come ittRe: Shalerrr rrr Shalerrr rrr 01/30/10 11:06AM
  Re: AV10 gurus...won't you come ittRe: . (Nick) . (Nick) 01/30/10 02:34PM
  Re: AV10 gurus...won't you come ittRe: Ben Ben 01/30/10 03:14PM
  Re: AV10 gurus...won't you come ittRe: Ben Ben 01/30/10 03:15PM
  Re: AV10 gurus...won't you come ittRe: Shalerrr rrr Shalerrr rrr 01/30/10 03:40PM
  Re: AV10 gurus...won't you come ittRe: Jesse Stephenson Jesse Stephenson 01/30/10 04:38PM
  Re: AV10 gurus...won't you come ittRe: . (Nick) . (Nick) 01/30/10 05:56PM
  Re: AV10 gurus...won't you come ittRe: the worst terry the worst terry 01/30/10 05:56PM
  Re: AV10 gurus...won't you come ittRe: Kelin Kelin 01/30/10 07:40PM
  Re: AV10 gurus...won't you come ittRe: Ben Ben 01/30/10 09:26PM
  Re: AV10 gurus...won't you come ittRe: Jesse Stephenson Jesse Stephenson 01/30/10 09:43PM
  Re: AV10 gurus...won't you come ittRe: Ben Ben 01/31/10 01:24AM
  Re: AV10 gurus...won't you come ittRe: naz naz 01/31/10 03:56AM
  Re: AV10 gurus...won't you come ittRe: . (Nick) . (Nick) 02/01/10 08:23PM
  Re: AV10 gurus...won't you come ittRe: . (Nick) . (Nick) 02/01/10 11:32PM
  Re: AV10 gurus...won't you come ittRe: Crackstar X Crackstar X 02/02/10 08:58AM
  Re: AV10 gurus...won't you come ittRe: Crackstar X Crackstar X 02/02/10 09:04AM
  Re: AV10 gurus...won't you come ittRe: Crackstar X Crackstar X 02/02/10 09:08AM
  Re: AV10 gurus...won't you come ittRe: kommut kommut 02/02/10 01:12PM
  Re: AV10 gurus...won't you come ittRe: kommut kommut 02/02/10 01:17PM
  Re: AV10 gurus...won't you come ittRe: Graham Motzing Graham Motzing 02/02/10 03:31PM
  Re: AV10 gurus...won't you come ittRe: naz naz 02/02/10 04:32PM
  Re: AV10 gurus...won't you come ittRe: Bret Hoffman Bret Hoffman 02/02/10 04:46PM
  Re: AV10 gurus...won't you come ittRe: . (Nick) . (Nick) 02/02/10 06:56PM
  Re: AV10 gurus...won't you come ittRe: Bret Hoffman Bret Hoffman 02/02/10 08:20PM
  Re: AV10 gurus...won't you come ittRe: . (Nick) . (Nick) 02/02/10 09:39PM
  Re: AV10 gurus...won't you come ittRe: kommut kommut 02/02/10 11:38PM
  Re: AV10 gurus...won't you come ittRe: Ben Ben 02/03/10 12:19AM
  Re: AV10 gurus...won't you come ittRe: naz naz 02/03/10 12:29AM
Click here to login.
