Re: bits to port cylinders
Rick /
Bits for non-ferrous metals (anything that doesn't spark-aluminum and other alloys) have fewer flutes and are straight cut, not cross hatched. This is to help keep them clean. Most bits are for ferrous metals such as stainless, steel and other hard metal that spark. As was said, hard to clog any of them up if you lube them with wax. Yes, the small metal slivers are a bitch. I keep a razor blade and tweezers handy for the cleanup. You can try to use gloves, but they get in there too and trash them unless you tape them up when you put them on.
The Harbor Freight crap is just that. You get what you pay for, don't get me started. If you plan on hacking out one cylinder you may get it done with only the frustration factor of using inferior products.
  bits to port cylindersTopic by: derek derek 01/27/10 12:12AM
  Re: bits to port cylindersRe: Charles Cole (OFMC) Charles Cole (OFMC) 01/27/10 12:20AM
  Re: bits to port cylindersRe: derek derek 01/27/10 12:29AM
  Re: bits to port cylindersRe: mit mortso mit mortso 01/27/10 12:57AM
  Re: bits to port cylindersRe: Sunset Paul Sunset Paul 01/27/10 01:20AM
  Re: bits to port cylindersRe: derek derek 01/27/10 10:41AM
  Re: bits to port cylindersRe: Gabe Bandit Gabe Bandit 01/27/10 11:25AM
  bits to port cylindersRe: Rick Rick 01/27/10 11:36AM
  Re: bits to port cylindersRe: Jesse Stephenson Jesse Stephenson 01/27/10 11:40AM
  Re: bits to port cylindersRe: latebreak latebreak 01/27/10 12:43PM
  Re: bits to port cylindersRe: Tom STL Tom STL 01/27/10 01:42PM
  Re: bits to port cylindersRe: Charles Cole (OFMC) Charles Cole (OFMC) 01/27/10 04:27PM
  Re: bits to port cylindersRe: Mars™   Mars™   01/27/10 04:49PM
  Re: bits to port cylindersRe: Sunset Paul Sunset Paul 01/27/10 05:27PM
  Re: bits to port cylindersRe: Tate Tate 01/27/10 05:51PM
  Re: bits to port cylindersRe: Jesse Stephenson Jesse Stephenson 01/27/10 05:57PM
  Re: bits to port cylindersRe: Gabe Bandit Gabe Bandit 01/27/10 05:57PM
  Re: bits to port cylindersRe: Gabe Bandit Gabe Bandit 01/27/10 06:06PM
  Re: bits to port cylindersRe: Jesse Stephenson Jesse Stephenson 01/27/10 06:10PM
  Re: bits to port cylindersRe: derek derek 01/27/10 10:56PM
  Re: bits to port cylindersRe: Tate Tate 01/27/10 11:28PM
  Re: bits to port cylindersRe: Jesse Stephenson Jesse Stephenson 01/27/10 11:42PM
  Re: bits to port cylindersRe: Britchez Britchez 01/28/10 12:40AM
  Re: bits to port cylindersRe: Rob @t ATTN! Burrito Rob @t ATTN! Burrito 01/28/10 02:17AM
  Re: bits to port cylindersRe: Sunset Paul Sunset Paul 01/28/10 05:07AM
  Re: bits to port cylindersRe: Rick Rick 01/28/10 09:57AM
  Re: bits to port cylindersRe: Gabe Bandit Gabe Bandit 01/28/10 10:25AM
  Re: bits to port cylindersRe: bryan bryan 01/28/10 04:54PM
Want to reply to this thread?
