Re: Over-Boring a Minarelli to 43mm
Noah K /
What is the 43 mm piston for? Are you sure it has the same dimensions as a minarelli piston other than the bore? I would say try to bore it to 47 or so, whatever the Minarelli Polini kit is and use a Polini piston. If its possible to make it that big, you'll just have to look and measure to see if it would open the ports up too much.
Click here to login.
