IS Hobbit polini good to replace nuked parmakit?
CtpEDsHED . /
My 1.5 hr old parmakit 70cc with a TJT, Proma, Jet , all that Jazz.
It sucked my de-comp in while setting the variator.
Too bad, it tore ass to 35 and I let up for a stop sign and brake check.
Acceled and slow loss of compression.
Gor for the pedal start --KRUNK KLUNK KRUNK.
I found my decomp valce jammed straight down the middle of my plug with the shroom end ripped of.
I had it RTV-copper to seal it, krack glue to hold it during cure and the pin in it.
It sheared the pin and sucked it.
SOOOO..
Do I buy the 8 port polini, or just do the parmakit again?
My head has bite marks in side, the piston rings gaot a good nick, and a booger sized stab in the cylider at the top of the bore.
I have pics.
If someone wants to save the cylider.
Thanks.
Click here to login.
