Re: 20 mm mikuni carb tuning
onell /
you MUST adjust the needle for your setup. I had a ton of problems with mine trying to get it tuned and now its pretty much perfect.
airsal, homoet, 20mm mikuni yielded me a 165 main jet with the needle second from the top setting. PLENTY of people have seen mine rip at the rallies. Its all about getting your main jet close, and then adjusting the needle... at least thats what worked for me.
  20 mm mikuni carb tuningTopic by: Andrew Andrew 01/24/10 02:56PM
  Re: 20 mm mikuni carb tuningRe: mattology - mattology - 01/24/10 03:15PM
  Re: 20 mm mikuni carb tuningRe: Andrew Andrew 01/24/10 03:24PM
  Re: 20 mm mikuni carb tuningRe: Dan Dan 01/24/10 04:31PM
  Re: 20 mm mikuni carb tuningRe: mattology - mattology - 01/24/10 07:21PM
  Re: 20 mm mikuni carb tuningRe: King Drunky JCams King Drunky JCams 01/24/10 09:08PM
  Re: 20 mm mikuni carb tuningRe: . (Nick) . (Nick) 01/26/10 07:35PM
  Re: 20 mm mikuni carb tuningRe: Andrew Andrew 02/06/10 10:09PM
  Re: 20 mm mikuni carb tuningRe: Weak-Ends Tj Weak-Ends Tj 02/06/10 10:30PM
  Re: 20 mm mikuni carb tuningRe: Not Tate Not Tate 02/06/10 10:52PM
  Re: 20 mm mikuni carb tuningRe: funk funk 02/06/10 10:55PM
  Re: 20 mm mikuni carb tuningRe: Andrew Andrew 02/07/10 01:47AM
  Re: 20 mm mikuni carb tuningRe: . (Nick) . (Nick) 02/07/10 10:49AM
  Re: 20 mm mikuni carb tuningRe: Weak-Ends Tj Weak-Ends Tj 02/07/10 11:08AM
  Re: 20 mm mikuni carb tuningRe: funk funk 02/07/10 12:34PM
  Re: 20 mm mikuni carb tuningRe: Chris R Chris R 02/07/10 01:27PM
  Re: 20 mm mikuni carb tuningRe: . (Nick) . (Nick) 02/07/10 01:27PM
  Re: 20 mm mikuni carb tuningRe: Andrew Andrew 02/07/10 09:16PM
  Re: 20 mm mikuni carb tuningRe: Nash . Nash . 02/07/10 11:48PM
  Re: 20 mm mikuni carb tuningRe: -Riprips- ** -Riprips- ** 02/08/10 12:36AM
  Re: 20 mm mikuni carb tuningRe: Name Removed Name Removed 02/08/10 02:37AM
  Re: 20 mm mikuni carb tuningRe: bryan bryan 02/09/10 04:34PM
  Re: 20 mm mikuni carb tuningRe: Rick Rick 02/09/10 04:47PM
  Re: 20 mm mikuni carb tuningRe: Name Removed Name Removed 02/09/10 09:42PM
  Re: 20 mm mikuni carb tuningRe: onell onell 02/10/10 04:14AM
  Re: 20 mm mikuni carb tuningRe: Jesse Jesse 09/25/10 06:24PM
  Re: 20 mm mikuni carb tuningRe: ggs ggs 09/25/10 08:15PM
  Re: 20 mm mikuni carb tuningRe: Dick Tortuga Dick Tortuga 09/25/10 08:41PM
  Re: 20 mm mikuni carb tuningRe: Krys D Krys D 03/11/11 10:23AM
  Re: 20 mm mikuni carb tuningRe: Chris R Chris R 03/11/11 09:01PM
  Re: 20 mm mikuni carb tuningRe: Jake P Jake P 03/11/11 09:54PM
  Re: 20 mm mikuni carb tuningRe: Krys D Krys D 03/13/11 10:23AM
Click here to login.
